Compustar & relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52197
Printed Date: May 15, 2026 at 2:24 AM
Topic: Compustar & relays
Posted By: Taito
Subject: Compustar & relays
Date Posted: March 19, 2005 at 8:57 PM
Me and my friend are kinda right in the middle of installing a compustar 2w900FM-AS on my 97 accord and we only have a couple of more wires to connect which are the door lock unlock, and a couple of other things.  We were talking to my buddies uncle who has installed alarms before, and said that we needed relays like six of them for the door, door unlock, park lights etc.  Do I really need that many extra relays?? Or any extra relays for anything?
Posted By: mo12v
Date Posted: March 19, 2005 at 9:16 PM
If your Instructions calls for Outboard relays, then U will need them.  I thought that unit had everything U need.
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightBLACK/ WHITE (-)20 PIN GRAY CONN. BEHIND DR. DASH *
Trunk Pin SwitchORANGE (-)20 PIN GRAY CONN. IN DR. KICK PANEL**
Parking LampRED / BLACK (+)AT HEADLIGHT SWITCH ***
Power LockBLACK/ WHITE3 PIN GRAY CONN. (COUPE/SEDAN)
Power UnlockORANGE4 PIN GRAY CONN. (WAGON) ****
* 20 Pin Gray Connector Located Behind Dr. Dash To Right Of Steering Column. ** SE Coupe: ORANGE (-) Wire Is Located In 16 Pin Conn. In Driver Kick Panel. *** RED / BLACK (+) Wire For Parking Lights Is Also Located In Brown Connector In Driver Kick Panel. **** Door Lock Connector Taped To Harness In Dr. Kick Panel, ....Negative Pulse Door Locks
Accessories
Window UpD\ RED / YEL P\ BLU/YEL D\ GRN/BLU P\ YELLOW @ MAIN SWITCH
Window DownF/ RED / BLU F/ BLUE R/ GREEN R/ YEL/GRN
Ign Key WarnBLUE/WHITE (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLUE/RED (-)STEERING COLUMN HARNESS *
HeadlightsBLUE (-)AT HEADLIGHT SWITCH **
OEM Alarm ArmN/A ***
OEM Alarm DisarmRED / BLUE (-)AT OEM ALARM UNDER PASS. FRONT SEAT
 Reversal Rest At Ground Power Window Circuit Diagram. * BLUE/RED (-) Horn Wire Changes To L GREEN/ BLUE. ** BLUE (-) Headlight Switch Wire Also Located In 10 Pin Gray Connector On Back Of Fuse Block. *** OEM Alarm Arms Thru OEM Keyless Remote Or Passively.
Remote Start
Tach SignalBLUETACH TEST CONNECTOR OR DISTRIBUTOR *
Ignition #2YELLOWIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3N/A
AccessoryWHITE/ BLACKIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightGREEN/ BLACK (+)AT GEAR SELECT SWITCH
Rear Window DefrostYELLOW/WHITE (-)AT REAR WINDOW DEFOGGER SWITCH **
* Tach Test Connector (2 Pin White Plug) Is Located On Passenger Rear Of Engine Compartment On Strut Tower. ** YELLOW/WHITE (-) Rear Window Defrost Wire Is Also Located In 18 Pin Blue Connector On Top Of Fuse Block.
MO
Posted By: Taito
Date Posted: March 19, 2005 at 9:46 PM
That is what I am wondering and asking. Do I NEED any extra relays to connect the power doors locks and etc...??
Posted By: tjdurham
Date Posted: March 19, 2005 at 9:59 PM
no just use your negative outputs to trigger the locks and your positive parking light wire and use the diagram above
tj
