Power loss to clock, after alarm Install
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52376
Printed Date: May 15, 2026 at 6:47 PM
Topic: Power loss to clock, after alarm Install
Posted By: juanes
Subject: Power loss to clock, after alarm Install
Date Posted: March 22, 2005 at 2:26 PM
Maybe someone can help me with this. I just installed a Crimestopper 2way pager alarm with remote start into my 2003 Chevy Silverado Z71. It works great! alarm, remote start and the two way pager, but the only thing I noticed after the install it my Clock looses its time every one and a while. Its very hard to recreate the problem. I think it happens when I turn the truck off with the door open. my stereo will remain on until I open the door, so I am wondering if I need to diode isolate a wire somewhere. I dont even have the door trigger hooked up to the alarm. I am using the dome light as the trigger, and that works just fine for me.. Can anyone suggest a resolution or something I should try to fix it? Thanks! Juanes
Posted By: dare_ds69
Date Posted: March 22, 2005 at 5:57 PM
did you powered all wires brown,orange,yellow,pink,white
------------- how own your mind, control your life.
MECP certified. always use a DMM
Posted By: juanes
Date Posted: March 24, 2005 at 2:20 PM
Clock resets to 12:00 come to think of it when I do a remote start the AC fan comes on the the truck starts. but when I turn the key to start it.. the stereo and AC Fan come one. I hooked up the Remote start how the manual said. maybe I am missing a wire.. any suggestions?
Posted By: juanes
Date Posted: March 24, 2005 at 2:24 PM
Forgot to say that the Radio does come on... Only after the truck in running. but not when it preps to start the truck. I hope I am explaining myself okay
Posted By: Acuraxtasy
Date Posted: March 24, 2005 at 10:39 PM
Sounds like you missed an accessory wire, sometimes there is more then 2 thats why it comes on when you turn on the key and not when you R/S the vehicle. As for the radio is it factory of aftermarket? And I would use the door trigger and not the dome light, some dome lights have a delay and if it is too long the alarm ignores it as an open/closed circuit upon arming.
Date Posted: March 25, 2005 at 7:49 AM
you need to power the brown wire
