2005 Honda Accord alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52488
Printed Date: May 16, 2026 at 4:09 PM
Topic: 2005 Honda Accord alarm/remote start
Posted By: methodikal
Subject: 2005 Honda Accord alarm/remote start
Date Posted: March 24, 2005 at 7:25 AM
Putting a dei 562T in a 05 Accord. I need the wiring, locations, and the key blank model. I have a 555H or a 556U. I also have a strattec code seeker to program keys. I'd prefer to use the 555H, but if the key blanks are available, I'll use that.
Posted By: dare_ds69
Date Posted: March 24, 2005 at 7:31 AM
12volts white  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red  +  ignition harness
Second Accessory WHITE/ red  +  ignition harness
Keysense RED / white or RED / black  -  ignition harness
Power Lock pink/black  -  grn plug, L side of fusebox
Notes: These wires will meter while using the passenger door lock switch.
Power Unlock pink/blue  -  grn plug, L side of fusebox
Lock Motor yellow/black  5wi grn plug, front of fusebox
Unlock Motor YELLOW /GREEN  5wi grn plug, front of fusebox
Parking Lights+ RED / black  +  large wht plug above fusebox
Parking Lights- RED / black  -  in steering column cover
Hazards GREEN/ red  +  large wht plug above fusebox
Turn Signal(L) RED / blue  +  large wht plug above fusebox
Turn Signal(R) brown  +  large wht plug above fusebox
Reverse Light green  +  driver kick, harness to rear
Door Trigger GREEN/ red  -  grn 5 pin plug behind fusebox
Dome Supervision use door trigger
Trunk/Hatch Pin blue/black  -  driver kick, harness to rear
Hood Pin yellow/red  -  hood pin switch in latch
Trunk/Hatch Release YELLOW /GREEN  +  driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm WHITE/ red  -  driver door module in door
Factory Alarm Disarm white  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer blue/red or blue  ac  ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25. On the 6 cylinder models it is in the gray connector A, pin 23.
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN/ orange  -  large wht plug above fusebox
Horn Trigger GREEN/ YELLOW  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
posted_image
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 556U or 555U
good luck
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: KarTuneMan
Date Posted: March 24, 2005 at 1:15 PM
You should be able to find a "keyless" override module for the imobilizer.
Check www.bypasskit.com  I dont know if DEI makes one yet. Asdtroflex makes one too its called OM honda5
also theres one for the factory security override ... IM honda3  check bypass kits .com they got it ALL
https://www.bypasskit.com/wizard.aspx   heres a link
