Disabling Viper Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52675
Printed Date: April 01, 2026 at 11:59 AM
Topic: Disabling Viper Alarm
Posted By: rigmover
Subject: Disabling Viper Alarm
Date Posted: March 27, 2005 at 12:11 PM
I'm not sure of the model but my Suburban is a '99 model and it had a Viper after-market system installed. Can someone please tell me how to disable it and enable it?
Posted By: swamprat323
Date Posted: March 27, 2005 at 1:57 PM
turn IGN on then off, then press the valet button withn 10 sec.
Posted By: auex
Date Posted: March 27, 2005 at 2:31 PM
Or depending on how old the alarm is, open door, hit lock, unlock, lock and the alarm should go into Valet.
If all else fails drive it into a lake!!!
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: rigmover
Date Posted: March 27, 2005 at 5:56 PM
Thanks for the replies. The lake idea isn't a bad one. It's a 3/4 ton land barge and the gas mileage is killing me. I've considered taping a $100 bill to the windshield, leaving the keys inside the ignition and hoping someone will just drive it away to put me out of my misery. But the $100 will only get them to the next gas station so that won't work. LOL.
Posted By: xdeliriousx
Date Posted: March 28, 2005 at 12:57 PM
swamprat323, that is the answer to my question too... Let me go out and try it and see if it works :) David
Date Posted: March 28, 2005 at 1:06 PM
swamprat323, could you give a more detailed instruction on how to do that? Like leave the door opened or close, how long must the ignition be on? how long do I hold the velet switch for, etc.... I couldn't get it to work :/ David
Date Posted: March 28, 2005 at 4:36 PM
once u turn in on turn it off right away and then press the valet button, All this be doen under 10 sec.
If dont work make sure the valet button is plug in all the way and make sure the IGN is hook up. To see if that is (im sure it is, but never know) that is it not in valet mose now, arm the system and turn the IGN on, if alarm sounds it hook up. remember that is if the system is not in valet mode.
Aslo try it form remote, make sure the door is open though.
