oem 2001 RHD Blazer immobiliser
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52714
Printed Date: April 01, 2026 at 3:48 AM
Topic: oem 2001 RHD Blazer immobiliser
Posted By: anbaautos
Subject: oem 2001 RHD Blazer immobiliser
Date Posted: March 28, 2005 at 7:41 AM
can anybody help. I have a customer with a 2001 chevrolet blazer RHD imported to the UK from canada. The oem immobiliser appears to have an intermittent fault. the security light and remote alarm/locking are working as they should, but it wont turn over every time , i have checked the starter motor & circuit and have concluded that it is the immobiliser at fault.I have been told by an ECU specilist that it is possible to bypass the ECU immobiliser and connect it to the BCU ?as i do not normally deal with OEM security systems i dont know how to do this or if it is possible.The customer would prefer to keep the OEM immobiliser if possible.
Posted By: Velocity Motors
Date Posted: March 28, 2005 at 9:10 AM
Do you know what kind of Immobilizer system is in the vehicle now ? You can try one of the databus modules instead of the resistor based ones and see if this method is more consistent.
------------- Jeff
Date Posted: March 28, 2005 at 10:23 AM
i believe this vehicle has databus immobilisation (when checking the alarm control unit i could only find a digital pulsed signal output to the vehicles ECU/BCU)
