LED wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5277
Printed Date: May 04, 2026 at 6:58 PM
Topic: LED wiring?
Posted By: 90CiViCSiR
Subject: LED wiring?
Date Posted: November 09, 2002 at 4:30 PM
I just need to know if it's possible and how I can wire some 3.7 volt led's in my car?
90CiViCSiR
Posted By: SOUND PRESSURE
Date Posted: November 10, 2002 at 3:29 AM
Posted By: djfearny2
Date Posted: November 10, 2002 at 9:53 AM
listen you can go to like radio shack or where ever you are getting the leds and this is what you got to get as well. you just need resistors that will drop the voltage from 12-14 to 3-5 cause an led rated at 3.7 can handel a little more. but no the more power will not make it light up more. the resistor value is 220ohm .5 tollerance. a resistor must be added to each led so the amout of leds you are buying you need resistors no prob though a pack of like five resistors is 99 cents., this is the value that will work for you i have done just this. on my car and my led are fine .
Jon
Installer/Help Technician
---coral springs florida---
