central locking
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52840
Printed Date: May 15, 2026 at 9:09 PM
Topic: central locking
Posted By: merseyscouse
Subject: central locking
Date Posted: March 30, 2005 at 7:50 AM
Hope someone can help me get my head round this....i have installed an alarm in my wifes 01 ford fiesta all works great EXCEPT...... central locking, i have yet to sort out.
A bunch of wires go into the door through the kick plate, i have tested them with a meter and found 2 wires that respond when c/l used
WHITE/ green   wire is positive  and yellow/blue  wire negative when door is unlocked .
same WHITE/ green wire is positive and yellow/blue wire negative when door is locked.
now how do i get the lock to throw ie where do i introduce the trigger pulse???? is there another wire that i have not included in this equation??
Posted By: Velocity Motors
Date Posted: March 30, 2005 at 9:11 AM
If it's a central locking system you have to use an actuator to throw the locking mechanism. Use two relays as well and wire them up like this: https://www.velocitymotorsport.com/images/install_notes/104.jpg
