Installing LEDs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52920
Printed Date: May 15, 2026 at 4:16 AM
Topic: Installing LEDs?
Posted By: crzycreations
Subject: Installing LEDs?
Date Posted: March 31, 2005 at 11:30 AM
Hey guys, I have some 3v, 20mA LEDs that I want to install in my car and i was wondering what stuff i would need to do from start to finish. If any of you would mind spending the time explaining it to me please? :) I'm mainly confused in where i tap to get the power, and fusing. thanks in advance ------------- -Don't buy it, Build it-
Date Posted: March 31, 2005 at 12:50 PM
I already know about the resistors and relays, just the other stuff pleez??
Posted By: dare_ds69
Date Posted: March 31, 2005 at 2:56 PM
well all depends where you are going to put?
------------- how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: March 31, 2005 at 3:06 PM
I was planning on putting them in the front dash area
Date Posted: March 31, 2005 at 4:09 PM
oops, sorry about that. I wanted to hook them up to a switch so i could just switch it on and off whenever. -thanks ------------- -Don't buy it, Build it-
Date Posted: March 31, 2005 at 5:30 PM
could i just hook 4 of them in series and not need a resistor?
Date Posted: March 31, 2005 at 6:05 PM
oops, my bad, i forgot: volts/current= resistance and in my case 12v/80mA=150 ohms ok so i've got that covered now where do i get the 12 volt source? what wire(s) should i tap into? ------------- -Don't buy it, Build it-
Date Posted: March 31, 2005 at 6:27 PM
ok, cool, thanks for your help bobk
