2003 oldsmobile alero remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53174
Printed Date: May 16, 2026 at 3:45 AM
Topic: 2003 oldsmobile alero remote start
Posted By: absolute_honda
Subject: 2003 oldsmobile alero remote start
Date Posted: April 03, 2005 at 10:41 PM
I was putting a remote starter on a 2003 oldsmobile alero and after putting in the pass 2 bypass and setting it at the right impedance, I hooked the rest of the wiring up.......  now for some reason the car will not start even with the key so i disconnected all the wiring and hooked everything up like stock and it still wont crank.   ANYONE WITH HELPFUL INSIGHT???? I also checked all fuses.  ????????????????????????
Posted By: auex
Date Posted: April 03, 2005 at 10:47 PM
Ok, what is the security light doing?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: April 03, 2005 at 11:26 PM
didnt even think of that
where is that located and what should i do - i tried disconnecting the battery and i even jumped the starter solenoid but when i jump the solenoid even with the key in the run position it only turns over and doesnt start???
Posted By: auex
Date Posted: April 04, 2005 at 12:25 AM
It was passock.
Date Posted: April 04, 2005 at 12:57 AM
got everything - customer had sh*tty omega pass2 bypass and the reostat was off by 0.1Kohm - got it working thanks for the help
