gm-u7 question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53370
Printed Date: May 15, 2026 at 1:52 AM
Topic: gm-u7 question
Posted By: floaterr
Subject: gm-u7 question
Date Posted: April 06, 2005 at 6:24 AM
1- the gmdl-bp says to hook up the OB-II wire last, while the gm-u7 says to hook up then plug the whole unit in while holding the program button. Is this still true and works without hurting anything?
2- The dome light input to door trigger output. Does this by any chance also elminate entering the doors to wire the door triggers? Meaning, when the door opens and the dome light comes on does the module send a ground down the wire to trigger the alarm?
Thanks for the help
Posted By: dare_ds69
Date Posted: April 06, 2005 at 6:32 AM
that product thas everything for you locks, door trigger, factory disarm and by pass the key just fallow the instructions
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: Captanham
Date Posted: April 07, 2005 at 12:25 AM
the databus doesn't send a ground really, it's a coded computer line basically, it will handle everything and convert it all to nice little wires that you tie into your alarm, they really make it a breeze, find the right one (trc makes some) and you can get it to controll the windows even (depending on what vehicle you are running it on)
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
