DEI 8618 starter kill relay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53439
Printed Date: May 14, 2026 at 8:29 AM
Topic: DEI 8618 starter kill relay
Posted By: kingtee45
Subject: DEI 8618 starter kill relay
Date Posted: April 06, 2005 at 10:54 PM
I have a DEI 8618 starter kill relay and a viper 560xv w/remote start also a 555L passlock  module to install in a 99 chevy tahoe 4 doors. the wires on the starter kill relay are orange 2 black wires pink and yellow. i have all the wires hooked up except for the yellow wire. it say's to hook this wire to the yellow wire of the 560xv alarm yellow wire, but the only problem with that is the yellow wire is in a ribbon harness coming from the remote start satlelite and plugs directly into the alarm. so what do i do with the yellow wire on the DEI 8618 starter kill relay?  Also have a DEI 516L voice module and how do i tie it in with the whole system and can i hook a field disturbance sensor on it and shock sensor on the alarm module. i realy need help on this one been on it for 3 days now.
kingtee45
Posted By: Captanham
Date Posted: April 06, 2005 at 11:32 PM
what is the yellow wire? you can split up the ribbon cable, or if your alarm has an aux. port for additional relays for things such as a secondary ignition or acc. output (i'm assuming that's what it is, if it's on the ribbon cable to the satalite relays) i haven't really worked much with the 516, but basically you give it power and then use a shock sensor or radar sensor or whatever and use the zone 1 and zone 2 outputs to activate.. atleast i think so, don't really listen to me on that one, i don't have a manual and i don't remember much about that one, but as far as the starter kill relay, the orange is usually the while running/armed - output, the black wires are probably the connection for the starters, and the yellow wire is probably just a fused positive to get the relay to click around, IF  that's what this is you can tie it to the ignition BEHIND the fuse on your alarm, or something like that... sorry if i ramble a lot
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Posted By: dare_ds69
Date Posted: April 07, 2005 at 6:48 AM
who made it i know it is a dei product,but i can't find it by 6818 who made it viper,hornet,phyton, or what?
how own your mind, control your life.
MECP certified. always use a DMM
