looking for install instructions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5354
Printed Date: March 22, 2026 at 7:24 AM
Topic: looking for install instructions
Posted By: 350toy
Subject: looking for install instructions
Date Posted: November 11, 2002 at 8:38 PM
ungo (clarion) g1100 alarm, i spoke to a couple dealers and they would not help me, they said they would be glad to install it for me for $150.00, so i'm hoping i can get the install instructions here, btw its going into an 84 toyota 4runner, thanks, Russ.
Posted By: Velocity Motors
Date Posted: November 11, 2002 at 8:53 PM
https://www.the12volt.com/downloads/file.asp?ID=285
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|BLACK/ white or black|+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|blk/yel or blk/red  |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|BROWN / white         |-  |door control relay *2       |
|     POWER UNLOCK|pink/white          |-  |door control relay *2       |
| PARKING LIGHTS +|green               |   |drivers kick panel          |
| PARKING LIGHTS -|RED / black           |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white or black|-  |2 pin plug top fusebox      |
|  TRUNK/HATCH PIN|GREEN/ red           |-  |drivers kick panel          |
|       TACHOMETER|black               |   |ignition coil *1            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ red           |-  |steering column *3          |
|           WIPERS|blue/black          |+  |steering column             |
|  LF WINDOW UP/DN|blue - blue / YELLOW  |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/blk - blu/wht   |A  |in drivers door             |
Notes:
*1 Can also be found BLACK/ white at pin IG- in the diagnosis connector under hood.  *2 Door control relay is located behind the drivers dash speaker.  *3 High-current ground, use relay.
Posted By: 350toy
Date Posted: November 11, 2002 at 9:24 PM
thanks jeff, this means nothing to me but my buddy is going to install it for me so i will print it out and give it to him!! Russ.
