2001 f-150 Tach Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53581
Printed Date: May 12, 2026 at 10:13 PM
Topic: 2001 f-150 Tach Wire
Posted By: cyclesounds
Subject: 2001 f-150 Tach Wire
Date Posted: April 09, 2005 at 2:20 AM
Is there a tach wire for my remote start without having to go to the engine? Thanks for your help.
2001 F-150 super cab 4.6 liter v8
Posted By: bretbowman
Date Posted: April 09, 2005 at 3:41 AM
Tachometer WHITE/ pink  ac  instrument cluster or PCM
FORD, F SERIES SUPER DUTY, 2001, Tachometer
Can also be located in the main harness that runs on the inside of the firewall to the left of the brake pedal.
Hope that helps!  Good luck!   posted_image
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
Date Posted: April 09, 2005 at 8:55 AM
Dont see that color wire on the instrument cluster. Is this the same for the non super duty trucks?
Posted By: MHARVEY
Date Posted: April 09, 2005 at 9:17 AM
i ended up using an injector wire for my tach signal. i have a 2001 f150 ext cab with 4.2L v6
Posted By: KarTuneMan
Date Posted: April 10, 2005 at 1:53 AM
At Ign coil    GREEN / WHITE or pink/white.... its a singal cylinder reading
in a harness that says AET TEST gray tape! Under hood pass. side on top of the valve cover
