Prostart CT-5000 Start Up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53697
Printed Date: May 11, 2026 at 8:11 AM
Topic: Prostart CT-5000 Start Up
Posted By: tinchote
Subject: Prostart CT-5000 Start Up
Date Posted: April 11, 2005 at 9:23 AM
Ok, after searching through previous threads on this system, I couldn't find anything about my problem. When power it up, it flashes the lights twice to ackowledge it started, and the LED stays flashing; no siren. I can put it in and out of valet mode (the usual way to stop the siren after you power it), but I cannot put it into programming mode, because I cannot flash the hood pin. I cannot even flash it with the built in programming button. Obviously there seems to be something wrong with my wiring. Any hints? Thanks a lot.
Posted By: tinchote
Date Posted: April 11, 2005 at 9:56 PM
No replies yet. Help, I need a hint! I don't have enough time to redo all the wiring again :)
Posted By: Velocity Motors
Date Posted: April 11, 2005 at 10:03 PM
Try removing the hood pin switch wire and grounding it manually with your hands to the chassis. Did you check to make sure that the ground that the hood pin switch is connected to is a good solid ground ? I had this problem with an Autostart as well and this solved my problem when I had it.
Posted By: tinchote
Date Posted: April 11, 2005 at 10:14 PM
I'll give it a try. That was my first guess, but before trying it I wanted to check if there were other options and if anything like that happened to somebody else. That poses the question: what's the behaviour of the CT5000 if you power it up with the hood closed?
Posted By: tinchote
Date Posted: April 15, 2005 at 6:41 PM
I finally found time to look at the hood pin switch. It was dirty and so it was not making good contact. After cleaning it, everything is working perfectly. Thank you very much for your help :)
