pass lock 2 bypass(Jeff)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5374
Printed Date: March 22, 2026 at 9:28 PM
Topic: pass lock 2 bypass(Jeff)
Posted By: brianh
Subject: pass lock 2 bypass(Jeff)
Date Posted: November 12, 2002 at 10:12 AM
I got the diagram that you posted for me but I dont quite understand where to hook up the wire that has the diode on it. You said to hook it to a wire that is grounded out while the engine is running(where do I find that wire?) Also why does pin 30 on the same relay go to ground? Sorry but I just dont see why you need it. Thanks in advance BrianH
Posted By: PLAYER69
Date Posted: November 12, 2002 at 11:26 AM
The wire he is reffering to is an output from the remote starter. It puts out a ground pulse while the remote start is running. As for your other question I would need to see the diagram but I would just do it the way it is suggested as it is right if jeff sent it to you ;)
Posted By: brianh
Date Posted: November 12, 2002 at 1:05 PM
Thanks for the info.I just couldnt fiqure out where to hook it up at. I know that Jeffs info was right I was just wondering why? I was not doughting him at all. He has helped me out alot! I only posted the topic with his name in it because he knew what we were talking about. Thanks again for the info. Brianh
