99 Saturn SC1 key problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5377
Printed Date: March 23, 2026 at 2:34 AM
Topic: 99 Saturn SC1 key problem
Posted By: mobileinstallat
Subject: 99 Saturn SC1 key problem
Date Posted: November 12, 2002 at 10:57 AM
I have one key fob factory remote only. I have two factory keys. my customers one key workes fine with the factory remote. His other key will not start the car unless he uses his factory remote to remotly unlock the doors first. then the second key will start the car.  Im thinking of just disabling the factory alarm. Any ideas? rather not get a second remote or install another keyless on this saturn this year/model is a pain. anyone ever just disable/ground the factory alarm without reprocutions? thanks in advance guys!
Mark
Date Posted: November 12, 2002 at 11:12 AM
PS :  I'm getting diff info that this model saturn has a passII  but other data says transponder?
can u post wire diagram please? thanks again
Mark
Posted By: Velocity Motors
Date Posted: November 12, 2002 at 4:24 PM
My information says it has nothing for an anti theft system ? That's wierd ? Did you look for Passlock II wires  in the ignition ?
Posted By: PLAYER69
Date Posted: November 12, 2002 at 4:30 PM
My info says the same as jeffs.  It does talk about a stater kill bypass though.
Date Posted: November 12, 2002 at 8:29 PM
Jeff,
no sign of PassII wires. like I said diff info all over for this make/year car.
Player69,
could you please post the info you have on the starter kill bypass?
Thanks!
Mark
Posted By: PLAYER69
Date Posted: November 12, 2002 at 10:30 PM
I will draw a diagram and post it shortly.
Date Posted: November 27, 2002 at 8:20 AM
thank you men,
 but - my customers discription over the phone was WRONG! (can you believe that),  I finaly got a chance to look at the car myself. it has no ign kill.heres the deal- one remote, two keys. using the remote will disarm alarm. but, using the keys to unlock the door will not disarm the alarm(factory alarm) also, the overhead door light will not go on when you open the door, unless you unlock them with the remotecontrole. when you try to start the car the alarm beeps the factory horn and flashes the lights. but only then you turn the ign key-it is not trigered by opening the doors. (ps: the car does start with both keys even in alarm mode).
my question is: is there an easy way to just ground the factory disarm wire WITHOUT removing the rear seat pass side panel? if there is what color and where?
any help is apr..
thanks again men!
MArk
