791xv install upgrade on civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53894
Printed Date: April 03, 2026 at 2:37 PM
Topic: 791xv install upgrade on civic
Posted By: anekin007
Subject: 791xv install upgrade on civic
Date Posted: April 14, 2005 at 6:11 AM
i got some question before i start with my install.   currently i have a 550 esp with remote start on my 2000 civic si.  i got a really good deal for a 791xv and i bought it cause i been wanting to upgrade to a pager.  people told me it is a easy upgrade.  comparing the two different alarm wiring diagram.  the 12 pin harness is the same so its plug and play.  same goes for the velet switch harness, 3 pin door lock harness, and led light.  the other harness are different but most of them are near each other and labeled the same so it pretty much simple to wires those up.  these are the ones that are not the same on the new alarm. so im not sure where to wires these up.
ORANGE / black 200mA anti-grind/ground when armed output
violet (-) 200mA starter trigger
orange (-) 200mA accessory trigger
pink (-) 200mA ignition trigger
yellow (+) ignition input to remote start
pink/white 200mA programmable ignition/accessory trigger
blue/white (-) 200mA 2nd status/defogger
GREEN / WHITE (-) factory alarm rearm
WHITE/ black (-) 200mA channel 5 output
blue (-) 2nd unlock output
for the relay satellite im not sure where to wire up any of them wires.  and why is there three 12v constant input on one harness?
here are the pictures of the wiring diagram that i been looking at and trying to figure out which wires are easy install and which i have no clue on.  sorry if the pics are too big.
550 esp
posted_image
791xv
posted_image
posted_image
Posted By: dare_ds69
Date Posted: April 14, 2005 at 7:24 AM
you have to take the old relays because the new brain it has different wire, you can not use the raimbow wires for the 550.
if you using a 555u or 556u you have to use the blue/white (-) 200mA 2nd status/defogger to activated the 555u
yellow (+) ignition input to remote start        pink/white 200mA programmable ignition/accessory trigger those  are the new raimbow wires from 791xv. there is a plug in the back of the satelite ralays were you have to put the raimbow wires as u see in the pictures.
GREEN / WHITE (-) factory alarm rearm              don't use
WHITE/ black (-) 200mA channel 5 output             if you are going to do windows up or down
blue (-) 2nd unlock output                                 don't use
change the antena, and there is a plug for brake(brown), tach(PURPLE / white), hood(gray),BLACK/ white,blue/white. just cut the old plug and match the colors,note: 550 it has two wires one is blue and the other one is blue/black one of those it has to be conected with the 555u.posted_image
how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: April 14, 2005 at 8:05 AM
i have the 530T already hooked up on my car.  i hope it doesnt effect the new alarm install.  since its already hooked up its already using one of the channel output correct?  im still confusing about some of the wires i mention and all the wires on the satellite relay.
Thanks for the help!
Date Posted: April 14, 2005 at 5:47 PM
don't worry the wire you need to control the 530t is the orange fron the brain because the new alarm already has a staret kill bild in if you see in the satelite relays there are a purple wire and a green wire, purple goes to motor side and green to key side.So the orange from the brain you don't have to conected so you can use to control the 530t to close the windows when armed and use the 4th chanel to roll down the windows.
