Clifford Concept 450
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53896
Printed Date: April 03, 2026 at 3:53 PM
Topic: Clifford Concept 450
Posted By: ronin8600
Subject: Clifford Concept 450
Date Posted: April 14, 2005 at 8:33 AM
I am getting a clifford concept 450 installed next week and was wondering if there is anything that I should make sure to go over with the installer before they install the alarm. Also in my reading on the internet I have heard that you may have to place fuses on the tail light because someone could use a screw driver to short out the light and kill your alarm, but I already have a fuse in my car for the parking lights, so is this still necessary?? Thanks in advance for all your help.
Posted By: cosmoworks
Date Posted: April 14, 2005 at 10:35 AM
Still need the parking light fuse. The car's built in fuse, only handles power from the parking light switch - but the alarm will supply it's own +12V to the parking lights so it still needs to be fused. Not to worry though, if your installer properly installs the alarm, he'll install both the 5A (brain) and 20A (pakring light) fuses that Clifford supplies in the right places and you'll be fine.
Date Posted: April 14, 2005 at 11:04 AM
Thanks for you help cosmoworks.
