delta pro 5005
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53925
Printed Date: April 19, 2026 at 5:32 PM
Topic: delta pro 5005
Posted By: flightrn
Subject: delta pro 5005
Date Posted: April 14, 2005 at 5:20 PM
anybody have an idea how to completely clear the 2 way remote and start over. have 2 vehicles and 4 remotes that work on both. causing broplems. wanting to get back to 2 for each vehicle seperately.    *****also does anybody have info on the 2 way remote. can't figure out what all the functions are. ex. holding the "c" button for a length of time changes some things but can't determine what. right now the 2way remote does not display any return info from the vehicle. range is still good though. ???
ANY HELP WOULD BE APPRECIATED
flightrn@ll.net
Posted By: prdjr165
Date Posted: April 14, 2005 at 8:06 PM
If you go thru the programing procedure for the remotes,it will omly accept 4 remotes,so all you have to do is hit the # 1 button twice on each one giving you 2 remotes for that vehicle,it should bump out the other remotes.
Holding the c(condition) button untill you hear a beep or see "con" then let go of the button,it will tell you if the vehicle is locked,un-locked,etc.
Posted By: flightrn
Date Posted: April 15, 2005 at 5:53 AM
THANKS for your reply.    by pressing con button and releasing after beep, nothing is returned (lock, unlocked ect) my other2way remote works fine though.  any idea what holding this button through 2, 3, 4 beeps does?(one is for snd on/off but does not act any differently if it is on or not.
also tried the "bumping " method.....one remote sill works for both vehicles...????  (the other is a new replacement for a 2way that died.)
any other ideas?
Posted By: prdjr165
Date Posted: April 15, 2005 at 7:34 PM
You might have a defective pager,if nothing shows up when con is pressed and your with-in range then I would say there is a problem with the remote.holding the con button for 1st set of beeps gets you chirps on or off.
2nd set gets you transmitter sound on or off.
3rd set gets you passive arming on or off.I had the same thing happen 2 remotes working 1 car,I just reprogramed the remotes to the specific car,to erase any previously stored transmitter codes,be sure to program all 4 transmitter memory locations.
