how to reset Viper?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53927
Printed Date: April 19, 2026 at 3:43 PM
Topic: how to reset Viper?
Posted By: LudeBoi
Subject: how to reset Viper?
Date Posted: April 14, 2005 at 6:16 PM
I am in a major trouble! I currently have a Viper 550esp and was trying to install a 690xv. for some reason the remote for the 690xv did not detect the brain. nor did the remote for the 550esp work with the 690xv. so i swapped out the antenna's (now the 550esp antenna is hooked up to the 690xv) the pager remote did not work. so i then programed the 550esp remote to the 690xv brain and it worked! but i only programmed the ARM button. so here is the problem. the alarm is going off and the only button that works is the ARM button. so now i cannot enter program mode because the alarm needs to be cleared. I need it cleared because I think the Responder antenna is screwed.
Posted By: auex
Date Posted: April 14, 2005 at 6:36 PM
How about trying to use the valet button to shut the alarm off? After that you should be able to go into programming. Check the install manual of both alarms to figure out how to erase all transmitters, or use a bitwriter.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: LudeBoi
Date Posted: April 14, 2005 at 6:39 PM
thanks for your response! i have no access to a bitwriter. to shut the alarm off i just pressed the ARM button again. and when i turn my ignition on and press the valet button. nothin happens and the light continues to blink
Posted By: auex
Date Posted: April 14, 2005 at 6:45 PM
Open door, turn key on, press the button for 1 second, the alarm will turn off after 2 seconds.
Posted By: LudeBoi
Date Posted: April 14, 2005 at 10:58 PM
ah! didnt work. I think either the antenna or the remote is messed up. not sure.
Posted By: swamprat323
Date Posted: April 15, 2005 at 8:40 AM
open door
turn key on then back off
then push valet switch.
