S-10 Blazer Doorlock Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53996
Printed Date: April 18, 2026 at 1:54 PM
Topic: S-10 Blazer Doorlock Problem
Posted By: Memphisman
Subject: S-10 Blazer Doorlock Problem
Date Posted: April 15, 2005 at 9:16 PM
I installed a RS/KE in a 2001 Chevy S-10 Blazer about 2 months ago. The customer came back yesterday and said that the power locks will not work at the switch, but work off the aftermarket remote and that the rear hatch release does not work at all. Any suggestions and/or solutions?
Posted By: mo12v
Date Posted: April 15, 2005 at 9:31 PM
Factory Fuses 1st.............
Not sure where U tied into wires, but make sure none of the Factory wires have been cut or split..........
Check factory RKE / BCM....
BCM IN FRONT OF CENTER CONSOLE
Did it have Factory Remote Keyless ?  If so, check them also
MO
Posted By: nava94
Date Posted: April 15, 2005 at 9:48 PM
make sure the plug at the switch is not loose or unplugged. check your connection did you solder or t-tap?Did you get the wires at the bcm?
Posted By: floaterr
Date Posted: April 16, 2005 at 1:42 AM
Also when installing did you do a 5 wire reversal setup or were you able to do a 3-wire positice?
Maybe a bad switch?
FYI: I rolled my Blazer off the showroom floor and in about a week the window lock switch blew up internally. Took it to the dealer and they didn't freakin listen to me and the service guy brought the truck back going, "a-durh, the driver switches work just fine... durh....". I walked over and pushed the passanger window and it wouldn't roll. Then the HVAC wouldn't do to the floor. Freakin assembly lines! LOL
