Omega AH-100-H in ’05 camry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54015
Printed Date: April 18, 2026 at 7:47 PM
Topic: Omega AH-100-H in ’05 camry
Posted By: Electromed
Subject: Omega AH-100-H in ’05 camry
Date Posted: April 16, 2005 at 2:57 AM
I just installed a Omega AH-100-H in '05 camry thanks in no small part to infomation I received here .This is a keyless entry alarm upgrade system with the optional shock sensor .Everything works except the door and trunk triggers .These cars have seperate grounds for all the electronics on board .With my trusty VOM I measured the door and trunk inputs ,they go from 12volts + when closed to 0volts when open but are not grounded and show no continutity to ground when open (measuring of corse to ground).That is why I'm guessing the door and trunk triggers that are negative (ground) aren't triggering ! How do I get these features to work without resorting to lots of relays or extra wires ? Wires I've checked are : Trunk/Hatch pin green DKP  and LF door pin ,RF door pin ,rear door pin with 3 diodes.As a side note I used the starter kill relay to disable the coil power  and hid it in the bottom of the engine compartment fuse box
Electromed
Posted By: eurotek
Date Posted: April 16, 2005 at 8:14 PM
interrupting the coil with a unit as unreliable as OMEGA, is a poor decision. if u found the wire that toggles from 12 to 0 when the door is opend and closed, connect it to the green on the alarm. if u found the correct wire as u described for the trunk, connect it to the blue wire. thats it. if it doesnt work, u either dont have the correct wire, ur connection is bad, or ur unit is bad.
Posted By: tjdurham
Date Posted: April 17, 2005 at 8:20 PM
there is nothing wrong with that omega module but interupting the coil is not a good thing to do because there is probally multi coils on that car
also the door triggers are at the left of the fuse box red\green dr  also red green pass red white rear doors ---- neg trigger to your green wire on alarm 3 diodes stripe facing vehicle
tj
