permanently bypass security
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54023
Printed Date: April 18, 2026 at 7:27 AM
Topic: permanently bypass security
Posted By: g0a_
Subject: permanently bypass security
Date Posted: April 16, 2005 at 10:12 AM
Hi guys
on a 2000 Grand Prix
is it possible to ground  the factory security wire  that disarms a factory alarm permanently
as in to chassis ground?
or would this cause a problem.?
thanks
Joey
Joey
Audio Illusions
3117 Hwy 70 SE
Hickory NC 28658
828-466-1515
Zero tolerance policy on prefab boxes
100% custom
Posted By: eurotek
Date Posted: April 16, 2005 at 7:59 PM
go ahead, ground it, i have never experienced any problems doing that, 14years installing, even did it on a lexus 400.. all the alarm knows is to stay off, u can always throw in a toggle switch.
Posted By: bretbowman
Date Posted: April 18, 2005 at 6:03 AM
Why would you want to perm. disable a perfectly good factory alarm?
I suggest making it work with your after market alarm for a little additional protection.
---->  Disabling factory alarms is reserved for ONLY the very NOVICE alarm installers.
If you need help making the two work together, you have the ENTIRE forum that is here and willing to help!
Go for IT!
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
Posted By: thepencil
Date Posted: April 18, 2005 at 9:23 AM
g0a_] wrote:
Hi guys
thanks
Joey
It's possible. The factory security has been paid for when the vechile was purchase why not use it.
Read this if you want to disable it. This is probably the better way to disable it.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
