93 acura legend, 530t
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54126
Printed Date: May 20, 2026 at 6:09 PM
Topic: 93 acura legend, 530t
Posted By: sydewayz_510
Subject: 93 acura legend, 530t
Date Posted: April 18, 2005 at 2:41 AM
its been about a month now and i'm ready to turn this one over to the dealer....i'm currently trying to install 2 530t window module on my 93 acura legend sedan...and so far i just got my driver window to work properly with the one-touch operation....next i tried to install my rear left window to the module and thats where the problem started....first i tried making the connections at the switch of the rear left door but that didnt seem to work...then i tried to make the connection at the motor wires on the switch side and it gave me a weird outcome....both the indiviual switch at the rear left door and the switch on the MASTER PANEL doesnt work anymore.....but the weird part is that the passenger switch, rear right switch controls the rear left window at the same time....and it could only move down but by an inch or so....then i flipped the LOCKOUT SWITCH on the MASTER PANEL to the off position and then back on again....but now nothing seem to work except the driver window.....i tired connecting all the wires back to its original place....and still nothing seem to work except the driver window....i checked the fuses at the driver kick panel and nothing is blown and also under the hood but nothing is blown....i also checked the power window relay in the driver kick and it works....so i dont really know what the problem is......i looked up the wiring diagram and it shows that the driver side window motor wire colors are RED / yel and RED / blk.....but the wire colors for the motors in the passenger, rear left, rear right windows are all the same blu/wht and blu/red...so i'm guessing sense i didnt connect the wires directly to the motor itself but instead i just connected it at a blu/wht and blu/red wire...i somehow cause a problem somewhere but dont know where......OHH...i also check the motor in the rear left door by connect a power source directly to it and it still works...so its not the motor.....please can someone give me a hand with this....i'm so frustrated and ready to give up....and let the dealers rip me off....any reply is greatly appreciated......thanks in advance......HELP!!!!!!!!!
Date Posted: April 20, 2005 at 1:22 AM
okay....i have checked all the fueses and the power window relay in the driver kick panel.....i also checked all the switch continuity on the MASTER PANEL and the rear left switch and motor.....what else can be wrong...please any suggestion will be great...thanks
Date Posted: June 27, 2005 at 2:46 AM
I have a 93 acura legend sedan and i'm trying to hook up two of the 530t window module to my alarm which is a viper 791xv.....my goal is to have both of the 530t window module hooked up to my driver door....i figure its easier for me to run all the wires to one door where i can control all the windows from there.....anyways i got the first module hooked up to the driver window and the passenger window and everything seem to work properly....the windows vents, roll down all the way, roll up all the way when armed.....NOW....i tried hooking up the two rear windows the same way i hooked up the two front windows and its not working right......only the rear left window is operating correctly along with the other two windows...and the problem i'm having with the rear right window is that it moves in the opposite direction of the other windows when armed....so for instance.....when armed all the other windows roll all the way up and the rear right windows rolls all the way down......and it wont vent either....please any adivce is greatly appreciated....thanks
Posted By: dare_ds69
Date Posted: June 27, 2005 at 7:19 AM
you hook up the second modules backwards. just switch the RED / white to the orange (orange make the windows goes up and RED / white makes go down) and you have to play whit the switches on the side of 530t
how own your mind, control your life.
MECP certified. always use a DMM
