98 maxima door lock problems?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5418
Printed Date: March 23, 2026 at 11:03 PM
Topic: 98 maxima door lock problems?
Posted By: sador
Subject: 98 maxima door lock problems?
Date Posted: November 13, 2002 at 2:24 PM
Hi everybody I hope someone can help me with this..
I'm working on 98 Maxima (Bose sound system and Security system)with Viper 790vx, everything is working fine remote start and alarm the only problem I have is the door lock and unlock I can't make them work! I found the lock and unlock wires they show 12 volt when you hit the switch and then rest (-)also I know is a double pulse but still,won't work any idea how can I make this door lock and unlock?Any help gonna be great!!!!!!!!thank you guys
Posted By: SnomanF150
Date Posted: November 13, 2002 at 3:02 PM
what I have says lt. GREEN/ Red for lock and GREEN/ YELLOW for unlock.. have to go to the drivers switch in the drivers door.. and yes.. neg double pulse for the unlock..
------------- George
David's Car Stereo
Baton Rouge, LA
Posted By: Chris Luongo
Date Posted: November 13, 2002 at 8:13 PM
And you test those wires by twisting the key in the door, not by using the switch.
Posted By: sador
Date Posted: November 13, 2002 at 8:22 PM
I test the all the wire in the driver door switch without using the key and the wires I found that work when I push the lock and unlock button was BROWN / white and brown then the rest was dead,I test the lt. GREEN/ Red for lock and GREEN/ YELLOW for unlock in the same swith but they don't do nothing,what can I do ?
Posted By: securinu
Date Posted: November 14, 2002 at 5:57 PM
snoman is right those wires are correct the one you have are probably the motor wires not the switch wires.
Posted By: sador
Date Posted: November 14, 2002 at 6:36 PM
ok I got it guys thank for your help" now the door lock and unlock work fine the only thing is when unlock you have to push twice the disarm buttom for the remote to unlock the doors;I know it's a double pulse negative but I don't know what else I have to do to unlock the doors with just one hit for the remote? Also I already change on the alarm menu for double pulse (-) but still the same.Anyways thaks a lot guys.
Date Posted: November 14, 2002 at 7:10 PM
I have a double pulse relay system.. will have to wait til I get back to work to get it.. I typed it online here somewhere if you want to search for double pulse locks in the forums.. just uses one relay, and a cap..
David's Car Stereo
Baton Rouge, LA
