94 ford LTD starter kill
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54347
Printed Date: May 20, 2026 at 5:24 PM
Topic: 94 ford LTD starter kill
Posted By: wop7
Subject: 94 ford LTD starter kill
Date Posted: April 21, 2005 at 8:44 AM
I am new to this but am ready to go! I would like to put a passive stater kill circut in my 94 crown vic but don't know the color of wires to attach to.
Can anyone help? I am trying to find a repair manual for my car now though.
I will also be installing the door lock/unlock circut in once I have an alarm with remote start installed. I will then need help on the color codes for that too.
Thanks in advance for pointing me in the right direction!:D
Wayne...
Oliver
Posted By: thepencil
Date Posted: April 21, 2005 at 9:12 AM
DIRECTWIRE™ WIRING INFORMATION - FORD / CROWN VICTORIA / 1994 / Remote Start
12volts yellow    +   ignition harness
Starter WHITE/ pink    +   ignition harness
Second Starter
Ignition RED / lt. green    +   ignition harness
Second Ignition
Third Ignition
Accessory gray / YELLOW    +   ignition harness
Second Accessory
Keysense
Power Lock pink / YELLOW      driver kick panel
Notes: Five-wire unless equipped with keyless - then negative pulse.
Power Unlock pink/green      driver kick panel
Lock Motor
Unlock Motor
Parking Lights+ brown      at switch or fuse box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BLACK/ lt. blue    +   either kick or ctsy lt
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release purple / YELLOW    +   switch or keyless mod.
Notes: Keyless module located at top of right kick panel under insulation.
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gray/orange    AC EDIS8 module dr.fender
Wait to start
Brake Wire lt. green    +   at brake pedal switch
Parking Brake
Horn Trigger yellow/lt. green    -   at steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: wop7
Date Posted: April 21, 2005 at 9:32 AM
Thanks for that quick responce and info!
Oliver
