98 Dodge Durango remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5454
Printed Date: April 23, 2026 at 7:13 AM
Topic: 98 Dodge Durango remote start
Posted By: Kyle45
Subject: 98 Dodge Durango remote start
Date Posted: November 14, 2002 at 4:53 PM
I installed my old Variant remote start in my Durango last weekend. It has been in a Isuzu rodeo working great. The Durango starts but then the remote box clicks and the Durango dies. Any clues?  I looked at the 1998 Durango alarm chart and I think I have hooked everything up correct, but I will double check this weekend. I can't remember if I have the Dark blue and the Black orange hooked up to the Ignition output or just one of them. Can I tie these together b/c there is only one output. The 2nd ignition output is a neg for Chevys.  Thanks for any input!
1998 Dodge Dakota Security Information
Constant 12V+Pink/Black or Red Ignition Switch Harness
StarterBlue / YELLOW Ignition Switch Harness
IgnitionDark Blue Ignition Switch Harness
Ignition 2BLACK/ Orange Ignition Switch Harness (Heat/AC)
AccessoryBLACK/ Orange Ignition Switch Harness
TachBLACK/ Gray Or Gray/Black At Coil Passenger's Side of Engine
Neutral Safety WireBROWN / White PCM Passenger's Rear of Engine next to Strut
Brake SwitchWHITE/ Tan Brake Switch
Trunk Pinn/a
Parking LightsBLACK / YELLOW (+) Behind Fuse Panel 74 Pin Connector below Fuse Panel
Head LampLight Green (+) Steering Column
Factory DisarmBLACK/ Orange (-) 16 Pin Connector behind Fuse Panel
Door TriggerYellow (-) Head Light Switch or Courtesy Light
Door LockORANGE / White Changes to GREEN/ Black 16 Pin Connector behind DR.
Door UnlockLight Green Dash next to Fuse Panel Reverse Polarity
Horn WireBLACK/ Red (-) Fuse Panel
Windows UpLF=Light Blue, RF=BROWN / White
Windows DownLF=White, RF=Purple White
Kyle
Posted By: PLAYER69
Date Posted: November 14, 2002 at 5:05 PM
Make sure your tach wire is correct and also make sure your unit learned the tach correctly or is programmed correctly.
You will need the blue ignition wire for the unit to run and the BLACK/ orange for the heater to work.  You shouldn't need extra relays as the remote start should have enough outputs.
Posted By: Kyle45
Date Posted: November 14, 2002 at 5:20 PM
Maybe thats it, I never had the tach cable connected before on the Rodeo, it didn't need it. I had cut it shorter, can I extend it without a problem?
Kyle
Posted By: securinu
Date Posted: November 14, 2002 at 5:32 PM
yes you can extend it and no dont connect the 2 circuits together , this is never a good idea. there is a reason they are seperate. better to be safe than sorry. if you want the accessories hooked up use a relay off the neg output.
Posted By: Kyle45
Date Posted: November 19, 2002 at 12:19 PM
The tach wire was the problem. It starts great now!  But now I have a new problem. I didn't realize it had an alarm, when I lock the doors and try to start it with the remote start the horn starts blaring. Of course if I don't lock my doors it starts the vehicle just fine. I need to lock my doorsposted_image   Any ideas? I lost my instructions for the variant alarm so I don't know what is triggering it.
Kyle
Posted By: securinu
Date Posted: November 19, 2002 at 12:31 PM
there is a green /orange wire in the plug left of the brake tap this to the factory alarm disarm signal out of the brain or you can permanetly defeat by grounding it.
Posted By: Kyle45
Date Posted: November 19, 2002 at 12:33 PM
Alright! Thanks!
Kyle
