clutch bypass problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54548
Printed Date: May 16, 2026 at 8:11 AM
Topic: clutch bypass problem
Posted By: wblakes
Subject: clutch bypass problem
Date Posted: April 24, 2005 at 6:37 PM
i installed a compustar 2w900fm on an 05 acura tsx/6spd about a week ago. this morning i went out to start the car with the key, it crank but won't start. after 30 minutes of frustration; (checking fuses and jump start the car), i decided to unhook the alarm and see what happens. for some reason i think it was the clutch, so i unplug my clutch bypass wire. start the car, VOILA!!! i plugged my clutch bypass wire back in and now the car is fine with remote or manual start. do anyone know why this happened??
Posted By: wblakes
Date Posted: April 24, 2005 at 7:01 PM
yeah, now that you mention it. it didn't crank when i didn't depress the clutch.
Posted By: xtremeaudio
Date Posted: April 25, 2005 at 2:19 AM
NOT THING WORNG WITH YOUR CLUTCH BYPASS YOU NEED TO CHECK YOUR KEY BYPASS
Posted By: Velocity Motors
Date Posted: April 25, 2005 at 8:59 AM
Did you use the same status wire for both the clutch bypass and the Immobilizer module ? If so, did you diode isolate the status wire for both functions ? When I do manuals & there are 2 or more devices taht need to be triggered during remote start, I use a relay to boost the (-) signal of the status wire and then wire up as many devices necessary from the one relay. This is just a thought seeing that if the clutch was still operational & the starter engaged but did not start, I would believe it was the Immobilizer that kicked in........ not the clutch bypass.
Posted By: thepencil
Date Posted: April 25, 2005 at 9:24 AM
Check your immoblizer bypass setup again. You don't have a clutch bypass problem.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: wblakes
Date Posted: April 25, 2005 at 9:31 AM
if it was an immoblizer problem then i would be able to start it manually with the key. but i tried starting it with the key myself and it didn't start either.
Date Posted: April 25, 2005 at 9:55 AM
Correction . If the car cranks and doesn't start, then the mmobilizer kicked in. The way the Immobilizer works is when something is not right ( like wiring, code variation or hard code ) the Immobilizer allows the starter to crank but no fule gets to the injectors and causes a no start fault. This will happen when you use your key or the remote starter. What bypass module did you use ? If it's not an updated software version bypass module, then your going to have problems withit. I had this exact same problem with an '05 Civic that I installed a module with an older software code on it and it would start great for about a month and then the customer would tell me that it wouldn't start for an hour and then it would all of a sudden be good again for about a week or so and then the same problem would arise.
Let me know what bypass module your using with the software version & hardware version.
Posted By: wblakes
Date Posted: April 25, 2005 at 8:50 PM
i'm using DEI 556u with my spare key.
Date Posted: April 25, 2005 at 10:40 PM
Chances are the key is not seated properly or is just slipping out of the sweet spot once in a while
