need wiring for 05’ Maxima
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54679
Printed Date: May 15, 2026 at 7:13 AM
Topic: need wiring for 05’ Maxima
Posted By: kauaikainoa
Subject: need wiring for 05’ Maxima
Date Posted: April 26, 2005 at 5:29 PM
wassup! anybody have the wiring schemz for the new 05' Maxima? I'm gonna do a Clifford with remote start w/ window modules... THANX!
BYRON DIZON
Posted By: thepencil
Date Posted: April 26, 2005 at 6:00 PM
DIRECTWIRE™ WIRING INFORMATION - NISSAN / MAXIMA / 2005 / Remote Start
12volts green (40A)   +   ignition harness
Starter BLACK/ red   +   ignition harness
Second Starter BLACK / YELLOW   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red   +   ignition harness
Second Accessory WHITE/ blue   +   ignition harness
Keysense BLACK/ red   +   ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is between the steering column and the fuse box.
Power Lock blue or pink/blue   -   driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock red (double pulse)   -   driver door module in door
Lock Motor gray   5wi BCM, pin 50
Unlock Motor green   5wi BCM, pin 44
Parking Lights+ RED / blue   +   driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red   -   BCM, pin 29
Turn Signal(L) GREEN/ black   +   BCM, pin 45
Turn Signal(R) GREEN/ YELLOW   +   BCM, pin 46
Reverse Light GREEN / WHITE   +   driver kick, harness to rear
Door Trigger see notes   -   BCM
Notes: The LF door is lt. blue in pin 62, the RF door is BROWN / white in pin 12, the LR door is RED / black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
Dome Supervision red   -   BCM, pin 48
Trunk/Hatch Pin PURPLE / white   -   BCM, pin 57
Hood Pin N/A
Trunk/Hatch Release blue or blue/white   -   BCM, pin 30
The fuel door release is green in the driver kick, in the harness to the rear. It is a high current negative wire.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT red or black   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire RED / green   +   brake pedal switch
Parking Brake pink/black   -   parking brake switch
Horn Trigger GREEN / WHITE   -   horn switch
Memory Seat 1 blue/white   -   ADP Control Unit, pin 9
Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in the dash.
Memory Seat 2 purple   -   ADP Control Unit, pin 25
Memory Seat 3 N/A   -
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: KarTuneMan
Date Posted: April 26, 2005 at 6:12 PM
you dont need the window modules.....
Send a 1 min pulse to the unlock....the 2 front windows go down
send the 1 min. pulse to the  lock, and they go up....
Posted By: metaverse
Date Posted: April 27, 2005 at 8:32 PM
Is that right ? A 60-second pulse ? Interesting info..not questioning..just verifying for future use..
Date Posted: April 27, 2005 at 9:29 PM
Beins I'm an astroflex dealer...Im lucky...All of there units have 4 programable outputs, all of wich can be prgrammed for any start features (start,acc,ign...etc.)     pulse times are 7/10 of a second 1 min, and 8 min. dome light, pulse before start, pulse after start.....and a whole lot more..KooL. Flexible
Date Posted: April 30, 2005 at 4:40 PM
hey everbody! Thanx sooo much for the info...... i just wanted to know just one more thing.. for the 05'  Maxima, non- bose, is there ne thing special about changing out the head unit.  I just got the mounting kit and harnesses.  I was just wondering if anything needed to be bypassed, or something like that
BYRON DIZON
