clifford 300, central locking
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=54832
Printed Date: May 13, 2026 at 7:24 PM
Topic: clifford 300, central locking
Posted By: ace.3
Subject: clifford 300, central locking
Date Posted: April 29, 2005 at 2:22 PM
hi all hears the problem,i have a clifford 300 and i wish to use it to lock and unlock the doors.
i have tried the relays and even a central interface modual.
basically the clifford lock pulses only 2 volts and the same with the unlock,how can i use the alarm to lock and unlock my car.
also the car is a ford escort s reg which is a 12 volt lock and unlock on it.
i have looked at the diagrams and everything i am at my teather with this.
Posted By: auex
Date Posted: April 29, 2005 at 7:45 PM
If the alarm is only putting out 2V then the alarm is bad. I would triple check that reading though.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: ace.3
Date Posted: April 29, 2005 at 7:54 PM
on the spec it say 150ma max from these wires lock and unlock,i have also put a meter accross it ,i was told that that is enough to go to a relay and switch that so to get a 12v suply to a motor,
r
Posted By: auex
Date Posted: April 29, 2005 at 9:17 PM
ma has nothing to do with the voltage it puts out. If it isn't sending out 12V then it won't operate a relay or anything else for that matter.
Posted By: ace.3
Date Posted: May 05, 2005 at 8:37 AM
took the alarm apart and found that some of the componets were burnt,and ic and a resistor,anyway even used a locking modual and nothing,so i binned it and bought another alarm,toad a 606i and fitted it with no probs all central locking a ok now.thanx for all that helped.
