remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55308
Printed Date: May 10, 2026 at 12:35 PM
Topic: remote start problem
Posted By: DOHOA
Subject: remote start problem
Date Posted: May 07, 2005 at 6:38 PM
I am installing the Omega max security and remote start sytem to my 2000 Toyota Celica .everything work fine  but the remote start engine has problem my car started only one or two minutes then shut down itself  and re restarted two times and shut down. I use tach less . Please help Thank you very much.
Posted By: mo12v
Date Posted: May 07, 2005 at 7:44 PM
U might want to "REPROGRAM" Unit to TACHLESS..........
Enter Programming Mode
Press Valet 34 times and Press LOCK
Or do a DEFAULT Program
MO
Posted By: DOHOA
Date Posted: May 08, 2005 at 7:20 PM
Thank you for your responsed. I have tried to enter the program mode but not working .Do you think because I use one Ignition wire from the alarm split to two for ignition 2 instead of using a relay. The problem is unable to enter the program mode..
Posted By: bighands23
Date Posted: May 09, 2005 at 1:30 PM
i have bought a magnum car alarm, and the remote start works but it doesnt start the car. all dash lights come on but starter will not engage. then i can start the car with the key and turn it back off but the alarm will keep it running. so the alarm thinks it started the car but it didnt and i can turn the car off with the alarm keypad, so its gotten me confused. help please
Ajah Fowler
Posted By: riceman
Date Posted: May 09, 2005 at 2:26 PM
just wondering did you guys use a relay to isolate the accessory wire because if you dont it can cause problems.
Posted By: OhioMike1101
Date Posted: May 09, 2005 at 5:37 PM
factory immobilizer?
