Chevy 2000 S10 Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55371
Printed Date: May 10, 2026 at 6:18 AM
Topic: Chevy 2000 S10 Alarm
Posted By: marshalmathersl
Subject: Chevy 2000 S10 Alarm
Date Posted: May 08, 2005 at 7:54 PM
Hi, I was wondering how I can tell if my oem keyless entry/secruity system would have to be bypassed if I was to have a remote start installed. Id like to know if I would have to factor in a the price of a pypass module into the price of the remote start.
Posted By: swamprat323
Date Posted: May 08, 2005 at 8:11 PM
yes your car has one i belive in 97 or 98 all GM cars has them.
Date Posted: May 08, 2005 at 8:18 PM
Thanks, I thought it did.
Posted By: Ravendarat
Date Posted: May 08, 2005 at 9:58 PM
Well. if you are asking about Passlock then yes you must bypass it, if you have a keyless entry remote with no actual alarm then there should be no aditional charge unless you want the remotes integrated together, and finally if you have a factory alarm and it goes off when the ignition is triggered then it must also be bypassed, but that one is generally fairly inexpensive.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
