Baretta ARC-1 wiring description
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=556
Printed Date: May 10, 2026 at 5:26 PM
Topic: Baretta ARC-1 wiring description
Posted By: bishop22
Subject: Baretta ARC-1 wiring description
Date Posted: May 01, 2002 at 12:07 PM
I recently purchased a Baretta alarm with a built in remote start that comes with 2 two button controls and a plug in antenna booster on the side.  The alarm it self is brand new but it is a 99 model.  My problem is that there were no instructions with it and unlike the new model the wiring description is not on the back of the alarm it -self.  I tried getting in touch with the manufacturer but have had no luck.  I was wondering if any-body out there had worked with this particular alarm and might be able to give some kind of information on what each wire is for .
                                                 Thanx
Posted By: Velocity Motors
Date Posted: May 01, 2002 at 2:34 PM
Do you have a model number fo the Baretta ?
Posted By: bishop22
Date Posted: May 01, 2002 at 9:11 PM
     I belive the model number for the alarm is Barreta arc-2 but I could be mistaken because the model number on the box is not very clear since it had some kind of tape on it and when it was removed part of the writing went along with it.
