Black Widow alarm any good?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=55764
Printed Date: May 06, 2026 at 10:47 PM
Topic: Black Widow alarm any good?
Posted By: hersheyloc
Subject: Black Widow alarm any good?
Date Posted: May 15, 2005 at 12:02 AM
Hey. I just need a very basic alarm system...is this one ANY good? https://www.blackwidowsecurity.com/1800.htm
Posted By: mo12v
Date Posted: May 15, 2005 at 1:32 AM
Depends on the definition of "GOOD" I have sold & installed Black Widow............Even know the Owner....... Is as "good" as a lot of other "good" Alarms...............Is also "better" than some............ Price is what U get.............
------------- MO
Posted By: nava94
Date Posted: May 15, 2005 at 7:40 PM
I have installed that model and it is okay. The antenna comes out thru the main plug you just have to be careful not to strech it or pull on it other than that it does it's job. The BWX5 2Way is okay too.It has more range than DEI 2Way. I tested these units BWX5 & Python 880, 881XP, and the Black Widow has more range even though you are inside your house and the car is 2 blocks away the signal goes thru.
Posted By: raydawg357
Date Posted: May 17, 2005 at 2:21 PM
One good thing about Black Widow, is their lifetime warranty on the brains. David Leavy stands behind their Black Widow products
------------- Do it right the first time
