2005 Suzuki Aerio SX
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56078
Printed Date: May 11, 2026 at 8:55 AM
Topic: 2005 Suzuki Aerio SX
Posted By: tkearl
Subject: 2005 Suzuki Aerio SX
Date Posted: May 19, 2005 at 9:39 PM
Anyone have a wiring diagram for a 2005 Suzuki Aerio? The one for the 2002 to 2004 are not close to my 2005 as far as I can tell. Anyway if you can tell me the 2005 one I would greatly appreciate it.
Posted By: thepencil
Date Posted: May 20, 2005 at 8:26 AM
DIRECTWIRE™ WIRING INFORMATION - SUZUKI / AERIO / 2005 / Remote Start
12volts WHITE/ green (60A)   +   ignition harness
Starter BLACK/ red or BLACK / YELLOW   +   ignition harness
Second Starter N/A
Ignition green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow/black   +   ignition harness
Second Accessory blue   +   ignition harness
Keysense blue/orange   +   ignition harness
Notes: Also found at the door lock controller above the driver kick panel, if equipped.
Power Lock BROWN / white   -   door lock control. above driver kick
Power Unlock brown   -   door lock control. above driver kick
Lock Motor RED / blue   5wi door lock control. above driver kick
Unlock Motor GREEN/ black   5wi door lock control. above driver kick
Parking Lights+ RED / yellow   +   driver kick, harness to rear
Parking Lights- RED / green   -   headlight switch
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red   +   turn signal switch
Turn Signal(R) blue / YELLOW   +   turn signal switch
Reverse Light red   +   driver kick, harness to rear
Door Trigger BLACK/ red   -   driver kick, harness to rear
Dome Supervision common with door trigger wire
Trunk/Hatch Pin BLACK/ white   -   light in trunk
Notes: On the wagons the hatch pin is common with the door trigger.
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT BLACK/ white or black   ac   any ignition coil
Wait to start N/A
Brake Wire GREEN / WHITE   +   brake pedal switch
Parking Brake BLACK/ red   -   parking brake switch
Horn Trigger BROWN / yellow   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Required:
No Type:
N/A
Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.posted_image
