01' ford explorer door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5624
Printed Date: May 13, 2026 at 8:25 AM
Topic: 01' ford explorer door locks
Posted By: mxxmikexx
Subject: 01' ford explorer door locks
Date Posted: November 18, 2002 at 9:11 PM
from a previous post someone posted that in order to "wake up" the door locks after the vehicle has been left for awhile, you need to pulse a BLACK / YELLOW wire in the drivers kick with a factory alarm disarm pulse from the remote starter unit your using. i wasnt able to find any BLACK / YELLOW wires, but there were a few yellow/black wires in the drivers kick. does anyone know how to test for this wire, is this wire coming out of the drivers door harness, or is it the other harness that runs down the kick panel to the back of the vehicle?
Posted By: PLAYER69
Date Posted: November 18, 2002 at 9:17 PM
It will be coming from the drivers door.
Date Posted: November 18, 2002 at 9:21 PM
are you sure its not yellow/black?
Posted By: PLAYER69
Date Posted: November 18, 2002 at 9:23 PM
it's BLACK / YELLOW according to my info.
Posted By: PLAYER69
Date Posted: November 18, 2002 at 9:35 PM
Did you try checking in the boot to see if it is there?
Date Posted: November 19, 2002 at 9:10 PM
when i looked there were about 3 yellow/blacks, but no BLACK / YELLOW coming out of the drivers door harness.
Posted By: PLAYER69
Date Posted: November 19, 2002 at 9:18 PM
I will look it up in the service manual tomorrow.
Posted By: PLAYER69
Date Posted: November 19, 2002 at 9:19 PM
Does it happen to have the keyless entry (buttons on the door)?
Posted By: PLAYER69
Date Posted: November 19, 2002 at 9:21 PM
This is a reguler explorer and not the sport trac correct?
My info shows the sport trac as being yellow/black and says it will be the one with the biggest black stripe.
Posted By: PLAYER69
Date Posted: November 19, 2002 at 9:23 PM
Another thing you can try, sit in the truck and wait for it to do the bcm shutdown. Put a key in the ignition (don't turn) and then see if you are unable to unlock the doors.
Date Posted: November 19, 2002 at 9:24 PM
the truck is coming back to me on saturday to finish the locks, so hopefully ill be able to figure it out with all this info, thanks for your help player69
