Car starts but dies after 2 sec
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56485
Printed Date: May 14, 2026 at 9:44 AM
Topic: Car starts but dies after 2 sec
Posted By: jkib
Subject: Car starts but dies after 2 sec
Date Posted: May 26, 2005 at 2:25 PM
Can someone help please, I have a toyota carmy 97 and i just installed (process)a viper 560xv, the car starts then dies after 2 sec. I hve tried all the recomended options e.g like rising the voltage as described by the maker and I can't get the car run for more than 2 sec.after reading more the book mentions something about installing a imobolizer kit P-555u. Do i need this item and if not what have i done wrong?
Posted By: thepencil
Date Posted: May 26, 2005 at 2:49 PM
NO you won't need that. Tach signal. Have the tach been learned? ------------- Be careful whose advice you buy, but be patient with those who supply it.
Posted By: mxxmikexx
Date Posted: May 26, 2005 at 3:25 PM
did you hook up both ignition wires? there should be a BLACK/ red and a BLACK / YELLOW wire. if you dont have both hooked up that could be your problem right there. you also mentioned turning up the voltage? so im assuming using a tachless mode with the remote starter?, DEI unite are pretty consistant with working in tachless, however it wouldnt hurt to hook it up in tach mode, and grabbing the tach wire.
On the 4 cylinder motor use the black wire in the gray plug at the coil on the drivers side of the motor. On the 6 cylinder motor use the gray wire located at the ignitor on a bracket just in front of the strut tower. The module says Denso on it.
P.S. a good way to tell if your missing an ignition wire is to put the key in the ignition (dont turn it), remote start the car and as soon as the car cranks, turn the key forward and if the car stays running then you know your missing an ignition wire!
and no, you dont need an immobilizer bypass for that year camry.
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
Posted By: tricky21
Date Posted: May 26, 2005 at 11:00 PM
go into the diagonsric shut down menu feature. It will tell you if it is a tach prob, ign, or +/- saftey shutdown.
