99 Nissan Altima door trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56666
Printed Date: May 15, 2026 at 10:30 PM
Topic: 99 Nissan Altima door trigger
Posted By: davidosand
Subject: 99 Nissan Altima door trigger
Date Posted: May 30, 2005 at 5:48 AM
I have 99 Nissan Altima and the database calls for a RED / white wire(-) door trigger wire at the drivers kick panel. I can't find this wire. Can anyone help? Thanks
Posted By: wblakes
Date Posted: May 30, 2005 at 9:16 AM
To avoid dome light delay use RED / green for the driver door, red for the front passenger door, and RED / black for the rear doors. All 3 three wires are located at the smart entrance control unit. Must diode isolate each.
The smart entrance control unit is located to the right of the steering column. It is black or blue in color.
Posted By: thepencil
Date Posted: May 30, 2005 at 9:20 AM
"Smart Entrance Control Timer" Is A BLUE Module Located Behind The Driver Dash To The Right Of The Steering Column.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
