wire diagram for 88'420 scl mercedes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5677
Printed Date: May 14, 2026 at 1:11 AM
Topic: wire diagram for 88'420 scl mercedes
Posted By: brianna
Subject: wire diagram for 88'420 scl mercedes
Date Posted: November 20, 2002 at 7:37 AM
please ------------- BSoliven
Posted By: skerr
Date Posted: November 20, 2002 at 2:25 PM
| 1986-91 Mercedes 420 Series Security Information | | Constant 12V+ | Red | Ignition Switch Harness | | Starter | Purple | Ignition Switch Harness | | Ignition | Pink/Black | Ignition Switch Harness | | Ignition 2 | Pink/Green | Ignition Switch Harness, Accessory 2 | | Accessory | Pink / YELLOW | Ignition Switch Harness | | Tach | Black | Coil | | Brake Switch | BLACK/ Red | Brake Switch or Anti-Theft Module | | Trunk Pin | BROWN / White (-) | Anti-Theft Unit | | Parking Lights | Gray/White L | And Gray R at Light Switch or Anti-Theft Module | | Head Lamp | WHITE/ Yellow | Light Switch | | Factory Disarm | GREEN/ YELLOW (-) | Anti-Theft Unit or Driver's Kick Panel | | Door Trigger | BROWN / White (-) | BROWN / Gray (-) at Anti-Theft under Passenger's Floor Board | | Door Lock | Blue or Green | Vacuum Lock at Anti-Theft or Pump next to Spare | | Door Unlock | Blue or Green | | | Horn Wire | BLACK/ Pink | Steering Column |
------------- Shawn
