Trunk Pin on Viper 791XV
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=56999
Printed Date: May 16, 2026 at 2:07 PM
Topic: Trunk Pin on Viper 791XV
Posted By: sleepy186
Subject: Trunk Pin on Viper 791XV
Date Posted: June 03, 2005 at 7:43 PM
This may be a stupid question and I'm just overlooking the pin-out in the manual - but where do you connect your trunk pin (-) on the alarm in order for the LCD remote to show your trunk has been opened? There are dedicated door and hood inputs, but none for the trunk. If it shares a wire with another sensor, such as a tilt sensor, when the tilt sensor is triggered, will the remote show trunk?
Posted By: swamprat323
Date Posted: June 03, 2005 at 7:56 PM
the blue wire on the 12 pin harness is for the trunk. look at the install guide at the back the quick wire guide.
Date Posted: June 03, 2005 at 8:03 PM
Thanks...the guide in the front doesn't mention it and I assumed the quick guide is just a repeat on the same info...I guess what the say about assumptions is true.
