power door locks on 1993 accord wagon ex
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57059
Printed Date: May 16, 2026 at 6:39 AM
Topic: power door locks on 1993 accord wagon ex
Posted By: bdby1977
Subject: power door locks on 1993 accord wagon ex
Date Posted: June 04, 2005 at 9:42 PM
i bought a prestige 2 way alarm model aps 996a im trying to figure out the power door locks the factory alarm is under the left front seat but it talks about a GREEN / WHITE 4  lock yellow/white 4 unlock  they say the wires either in the left front door harness or its under rear seat i havent found it  does someone have a pic or could tell me what i need to look for  i have tried everything and still cant find the wires thanks
Posted By: mo12v
Date Posted: June 05, 2005 at 8:55 AM
Wagon Door Lock Wires Are GREEN / WHITE For Lock And YELLOW/WHITE For Unlock. Wires Are Located In Driver Door Harness Or Under Rear Seat
There is a harness that goes thru the Driver door from Kick Panel
OR
The harness that is under the rear seat has the correct wires also
Be sure to test with a meter
MO
