97 Nissan Maxima Door unlock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57151
Printed Date: May 15, 2026 at 6:57 AM
Topic: 97 Nissan Maxima Door unlock
Posted By: nima
Subject: 97 Nissan Maxima Door unlock
Date Posted: June 06, 2005 at 7:52 AM
         I have problem with unlock the car .its lock the car with remote but not unlock.i connect unlock wire to GREEN/ YELLOW wire on door SW but its not doing anything.any help will be good
Posted By: mo12v
Date Posted: June 06, 2005 at 8:56 AM
This vehicle requires a DOUBLE Pulse for Unlock.........
R U using a Double Pulse generator or have you tried the UNlock wire for 1 pulse or 2?
U may require a stronger ground also thru Relays
MO
Posted By: nima
Date Posted: June 06, 2005 at 9:16 AM
I try to connect direct from unit to door lock switch.but its not doing anything.i have buldoge RS122 remote start
can you tell me how to connect the relay.can you send me the diagram
Posted By: thepencil
Date Posted: June 06, 2005 at 10:05 AM
Program the alarm unit to a double pulse first as advice by mo12v. Below is the wire diagram for a stronger ground connection. I think it is a double pulse related issue rather than a ground issue.
posted_image
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Posted By: nima
Date Posted: June 06, 2005 at 11:57 AM
How to program for double pulse?i have buldoge RS122
Date Posted: June 06, 2005 at 3:42 PM
Posted By: OhioMike1101
Date Posted: June 06, 2005 at 9:01 PM
I have done a couple maximas and you hit the DL wires in the door at the cylinder.  You will def need a double pulse for unlock.  You do not need a stronger ground either as you are hitting the wires b4 the factory relays.
I do not believe you can 2 step those DL outputs.  You may just hve to hit the unlock button twice.
