1990 Grand Am
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57219
Printed Date: May 15, 2026 at 8:34 AM
Topic: 1990 Grand Am
Posted By: stash3123
Subject: 1990 Grand Am
Date Posted: June 07, 2005 at 10:44 AM
Hi all-this is my first post and I need some help. I'm looking for a wiring diagram for a 1990 Grand Am LE and also can anyone also tell me where I can find/how I can access the ignition switch harness. I'm trying to install power locks/keyless entry/ignition kill switch. Thanks.
Posted By: shortdogchap
Date Posted: June 07, 2005 at 12:31 PM
| 1990-91 Pontiac Grand Am Security Information | | Constant 12V+ | Red | Ignition Switch Harness | | Starter | Purple | Ignition Switch Harness | | Ignition | Pink | Ignition Switch Harness | | Accessory | Orange | Ignition Switch Harness | | Tach | White | Or PURPLE / White (-) At Coil or Multi Coil Pack | | Brake Switch | White | Brake Switch | | Trunk Pin | n/a | | | Parking Lights | Brown | Light Switch | | Head Lamp | Yellow | Light Switch | | Hood Pin | n/a | | | Factory Disarm | n/a | | | Door Trigger | White (-) | Driver's Pin Switch | | Door Lock | Light Blue | Driver's Kick Panel | | Door Unlock | Black | Positive Trigger | | Horn Wire | Black (-) | Steering Column |
------------- steve
Date Posted: June 07, 2005 at 12:57 PM
Thanks shortdogchap, that was really helpful. If anyone else out there knows how I can access the ignition switch harness I'd really appreciate it.
