Wiring Diagram Ford Fiesta 95
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57472
Printed Date: May 13, 2026 at 9:54 PM
Topic: Wiring Diagram Ford Fiesta 95
Posted By: Danceheaven
Subject: Wiring Diagram Ford Fiesta 95
Date Posted: June 11, 2005 at 9:18 AM
Hey guys im after a Wiiring Diagram Ford Fiesta 95 Si model
Cheers
Date Posted: June 12, 2005 at 7:59 AM
BUMP
Posted By: dare_ds69
Date Posted: June 13, 2005 at 6:30 AM
Starter blk/blu or grey    ignition harness
Ignition black or green    ignition harness
Accessory yellow    ignition harness
Power Lock yel/blk or yel/blu   +  either kickwell
Power Unlock wht/vio or wht/grn   +  either kickwell
Parking Lights+ blue & blu/red   at the steering column
Door Trigger BLACK/ red   -  n/s kick panel
Trunk/Hatch Pin ORANGE / black    at the bootlight
Trunk/Hatch Release ORANGE / black    at the release switch
Tachometer WHITE/ blue    alternator
Brake Wire violet/black    brake pedal switch
hopes it helps posted_image
how own your mind, control your life.
MECP certified. always use a DMM
Date Posted: June 14, 2005 at 4:22 PM
Thanks for that mate, i think thats from newer models,
As most of the wires haev since chnaged colours kinda confusing but got most wired up, im having a few problesm trying to locate power locking and power unlocking wires however, should it be a negative or positive pulse on the fiestas? ive DMM on almost every wire going to the door and no one jumps out as been a pulse some are gnd all the time some are 12v all the time but nothin pulses some do switch to 12v from gnd howvere but like i say they stay there untill doors unlocked they dont pulse in any case any ideas?
