Pats bypass 2002 Mustang
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5750
Printed Date: May 15, 2026 at 10:44 AM
Topic: Pats bypass 2002 Mustang
Posted By: telenutt
Subject: Pats bypass 2002 Mustang
Date Posted: November 21, 2002 at 11:34 PM
I am installing a Viper 550 ESP in a 2002 Mustang. Anybody have any idea as to which transponder bypass module I need? I can order a 555F, but cannot get a straight answer from dei.Help????
Posted By: mxxmikexx
Date Posted: November 21, 2002 at 11:40 PM
555f should  work fine for you
Posted By: 10nesne1
Date Posted: November 21, 2002 at 11:44 PM
You will have to program the 555F to your ignition switch.  The 555F doesn't work very well.  You need all the keys together in order to program it.  The instruction is simiple.  The 555U works the best and you will lose a key.  Have fun.
Posted By: Derek
Date Posted: November 22, 2002 at 8:27 PM
telenutt,
Go to the nearest Ford dealer, go to the parts dept. and ask for a # 1 securilock interface kit ,part # 1L3Z-19G365-AB. You won't need a third key or a 555anything. It list for around 42 bucks, I think thats still cheaper than buying another key and a 555. Besides its spacifically made for this application. After that, if you need any further assistance...
Derek.
Posted By: DanDan
Date Posted: November 23, 2002 at 2:20 PM
Go to Ford and get the Ford Bypass.  There are 3 different types for Fords depending on year and model.  I pay $21 for them.  I cannot find my application guide for that model right now but Ford will have one.  The biggest Ford parts distributor is Delray Lincoln Mercury  in Delray Beach Fl.  It's a Code Alarm piece made for Ford but they always work for me.  Make sure you have two valid keys to program.  It's very easy.
DanDan
