Car Alarm Owning me
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57502
Printed Date: May 14, 2026 at 12:48 AM
Topic: Car Alarm Owning me
Posted By: GotBeat50
Subject: Car Alarm Owning me
Date Posted: June 11, 2005 at 7:17 PM
Hey guys new guy and need some help
Late last night my alarm crap the bed after trying to turn the key something went and the alarm stays armed. Theres no valet button or anything.
Conclusion made was that we have to find whatever powers the kill switch so I can at least get my car started again since its just sitting.
Heres the info
Car - 1989 Ford Mustang 5.0
Alarm - Chapman Alarms - FCC: GOH-MM8-101890 / DOC:1409 K791
if anyone knows where I can find a wiring diagram for this alarm that would be great
Posted By: draasch
Date Posted: June 11, 2005 at 7:52 PM
you need to find the main unit and unplug the wiring harnesses.....see if that will allow the car to start...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Date Posted: June 12, 2005 at 10:40 AM
we found a unit that switches on it but once removed nothing changed.
This it possible that theres a whole differ unit for the kill switch?
Posted By: KarTuneMan
Date Posted: June 12, 2005 at 11:04 AM
Unplugging the brains main harness wil NOT release the starter kill relay....You need to find the starter wire, and put it back together. It should be WHITE/ pink!  Take the starter kill relay out and reconect the starter wire
Date Posted: June 12, 2005 at 11:47 AM
where exactly can I find those wires in the bay or under the dash?
Posted By: auex
Date Posted: June 12, 2005 at 1:00 PM
They should be under the dash in the wires running to the ign switch.
Wouldn't it suck if all that was wrong was the starter solenoid? Or worse the starter was bad?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: June 12, 2005 at 1:22 PM
I dont think thats the deal cause it was fine all day then when I went to start the car it did what a bulb does when it goes that whole flash then nothing.
It just stays armed no matter what and the little module thing that recieves the signal from the remote like buzz's and such
