99 F350 door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57714
Printed Date: May 15, 2026 at 7:30 PM
Topic: 99 F350 door locks
Posted By: Steve242002
Subject: 99 F350 door locks
Date Posted: June 14, 2005 at 11:09 PM
Hi everyone, so this is my first post wi the 12 volt and I am asking for help.  I just installed a compustar with all the bells and whistles, but i cant seem to get the doors to lock or unlock.  All the forums I read and the documents from directecs say there is a pink/lt. green and a pink / YELLOW wire in the drivers kick panel, I have found other sources that say they are in the passanger kick panel, I CANT FIND THEM ANYWHERE!!!  I can locate them at the switch but then they are gone, i cant locate them anywhere else, the alarm put out a -trigger but as far as i can tell the door locks area positive triggered system, or a reversal, im not sure.  Any help would be greatly appreciated.;  Thanks
Posted By: mo12v
Date Posted: June 15, 2005 at 9:36 AM
You can get wires in Driver Door Frame Boot
or Try:
Power LockPINK / YELLOWEITHER KICK **
Power UnlockPINK/GREENPANEL ***
** With OEM Keyless Entry ......Negative Pulse Door Lock
***W/out OEM Keyless Entry....../Reversal Rest At Ground Door Lock
Alternate Locations and/or Wire Colors:
 Gray 16 Pin Conn. To Right Of Steering Column. W/ OEM Keyless Entry, Doorlock Wires Can Be found In Same Gray 16 Pin Conn. As Door Trigger.
W/O OEM Keyless Entry, Alternate Door Lock Switch Wire Location Is Behind Glovebox, Above Heater Case. Test for Switch Side From Driver's Switch.
MO
Posted By: davedyer79
Date Posted: June 15, 2005 at 10:52 AM
mo12v is right, I have found them to the right of the steering column harness.  I have also found them to the left of the steering column also, in a white box attached to the bottom of the dash.  You will see 3 plugs in the box.  You can find your parking, locks, horn, and dome here.  (I am assuming that your truck has factory keyless)
davedyer79
Date Posted: June 15, 2005 at 11:11 AM
No, the truck doe not have OEM keyless, so i am assuming that its a reversal switch right?
Date Posted: June 15, 2005 at 4:04 PM
ok, i got the door locks figured out but now i need some help connecting the power windows to the aux 1, how would i do that?
