Jeep Wrangler 1999 Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57792
Printed Date: April 18, 2026 at 10:55 AM
Topic: Jeep Wrangler 1999 Alarm
Posted By: emsjames007
Subject: Jeep Wrangler 1999 Alarm
Date Posted: June 15, 2005 at 11:03 PM
I am attempting to install my first car alarm on a 1999 Jeep Wranler Sahara. The alarm is a Scytek Galaxy 5000 RS2W1-SP with a micro wave sensor. I got this for when I take the top off. I am a General Foreman on a 97 MW Peaker Plant that the company I work for is doing the electrical installation on. I've done some pretty complex control wiring, But I have to say that when my alarm arrived it scared me. Any help would be appreciated especially a wiring diagram on the jeep.
Thanks in advance
James R.
Posted By: mo12v
Date Posted: June 15, 2005 at 11:13 PM
Constant 12 voltsPINK/BLACK & REDIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)AT ANY PIN SWITCH
Trunk Pin SwitchN/A
Parking LampBLACK / YELLOW (+)AT HEADLIGHT SWITCH
Power LockNOT OFFERED IN VEHICLE
Power UnlockNOT OFFERED IN VEHICLE
Accessories
Window UpNOT OFFERED IN VEHICLE
Window DownNOT OFFERED IN VEHICLE
Ign Key WarnL BLUE (-)STEERING COLUMN HARNESS *
Trunk ReleaseN/A
OEM HornRED / YELLOW (-)14 PIN CONN IN DRIVER KICK PANEL
HeadlightsL GREEN (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
* Key Sense Wire only Grounded With Driver Door Open And Key in Ignition.
Remote Start
Tach SignalGRAYAT COIL OR PCM *
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACK/ D GREENIGNITION SWITCH HARNESS
Neutral SafetyBROWN / L BLUE (-)AT SWITCH ON TRANSMISSION OR PCM *
Brake LightWHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDEL
Reverse LightVIOLET/BLACK (+)AT SWITCH ON TRANSMISSION OR DR KICK
Rear Window DefrostD BLUE/L GREEN (-)AT DEFOGGER SW. (HARD TOP ONLY)
* Powertrain Control Module (PCM) Located On Passenger Side Rear Engine Compartment Above Heater Fan On Firewall.
Immobilizer Bypass  (ONLY With Gray Key).
MO
Date Posted: June 15, 2005 at 11:25 PM
Thanks for the wiring diagram MO.
I do have the immobilizer could someone recomend a bypass module or a fix for my Jeep.
James R.
Posted By: mo12v
Date Posted: June 16, 2005 at 9:29 AM
OMEGA makes a PASS-4 which you will need to insert 1 coded ignition key
There are other Universal ones also
MO
