03 Odyssey EX sliding door
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57868
Printed Date: March 22, 2026 at 1:54 PM
Topic: 03 Odyssey EX sliding door
Posted By: Odyssey03
Subject: 03 Odyssey EX sliding door
Date Posted: June 16, 2005 at 11:13 PM
Hi guys. I need your help. I am installing a remote starter on a 03 Odyssey EX. Eveything goes fine. Now I want to use the "open trunk" wire from the remote starter to just OPEN the passenger side sliding door. This channel can be set to be + or - with 0.75 seconds and up duration. From previous discussions, it appears I only need to connect the WHITE/ Blue and the Light Green pins at the control switch to accomplish this. If somebody can confirm this and show me a better way to do it. Many thanks.
Date Posted: June 17, 2005 at 8:52 AM
I am installing a remote starter on a 03 Odyssey EX. Eveything goes fine. Now I want to use the "open trunk" wire from the remote starter to just OPEN the passenger side sliding door. This "open trunk" channel can be set to be + or - with 0.75 seconds and up. From previous discussions, it appears I only need to connect the WHITE/ Blue and the Light Green pins at the control switch to accomplish this. If somebody can confirm this or show me a better way, it is greatly appreciated. Many thanks.
