05 chrysler 300 keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=57892
Printed Date: March 22, 2026 at 2:09 AM
Topic: 05 chrysler 300 keyless entry
Posted By: crumbag
Subject: 05 chrysler 300 keyless entry
Date Posted: June 17, 2005 at 11:08 AM
I have a 05 chrysler 300 that i am doing a keyless entry keypad on and my problem is that when you lock the car with the factory remote the factory security system disables the doorlock switches after a few minutes.  Does anyone know any way that I can get around this.
thanks for any help
Posted By: mo12v
Date Posted: June 17, 2005 at 4:50 PM
If you UNLock car with key and open door, doesn't the door locks become operational again?
I think you can pulse a NEGATIVE to the Door Trigger & wake it up.....
MO
Posted By: crumbag
Date Posted: June 17, 2005 at 5:03 PM
well the guy aparently loses or locks his keys in the car a lot. If you're talking about pulsing the door lock trigger wire or the factory alarm un-lock trigger wire?
Posted By: mo12v
Date Posted: June 17, 2005 at 10:40 PM
U should be able to send a pulse from your keypad to wake up system at the same time as U UNLock the doors..........
MO
Posted By: crumbag
Date Posted: June 19, 2005 at 9:35 PM
would you happen to know which wire(s) i need to pulse and what resistor (if any) i need....
Posted By: dare_ds69
Date Posted: June 20, 2005 at 6:52 AM
if you sent a pulse to the door trigger you will trigger the factory alarm, you have to use relay and resistance
Power Lock PURPLE / dk. green  -  DKP or cluster, gry 26P plug, pin 5
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
or try to get the 456l this is a learnig module resistor, that way you don't have to use realays.
how own your mind, control your life.
MECP certified. always use a DMM
Posted By: crumbag
Date Posted: June 20, 2005 at 11:26 AM
This is how i already have it wired.  the problem is that the factory security system won't accept any input from that wire if the car was locked with the remote setting the alarm....
